MOD Duo Technical Specs
Jump to navigation
Jump to search
Technical specs
- length: 186 mm
- width: 160 mm
- height: 75 mm
Processors
- A20 CPU:
- Dual Core ARM A7 1.0GHz
- 1 GB RAM
- 8 GB Flash Storage
- Audio CODEC:
- Model: CS4245
- Manufacturer: Cirrus Logic
- DAC: 104dB dynamic range, -90dB THD+N
- ADC: 104dB dynamic range, -95dB THD+N
- 24 bit / 48 kHz AD/DA
Audio
- TS connectors;
- Input impedance 1 MΩ
- TRS noise cancelling;
- Headphone output:
- 6.35mm TRS connector
Each input/output uses a TRS connector, a True Bypass circuit, and has a LED whose color depends on the audio signal amplitude. Learn more about the Duo LED indicators here.
USB
- USB Host
- Connector: Type-A
- Standard: USB 2.0
- USB Device
- Connector: Type-B
- Standard: USB 2.0
Device Controller
- 2x 2.7" LCD display
- 2x footswitches with color LEDs
Software
The MOD Duo runs the latest MOD Operating System.
