How build Plugins using Docker
Last update: 11 February 2026
This document contains information on how to build your audio plugins for the MOD devices, specifically for non-Linux hosts such as macOS or Windows, using Docker.
To build a plugin using Docker, you will need to follow these steps:
Step 0: Install Docker
Before we start building, we need to install Docker, as the cross-compilation steps are meant to be used under a Linux host, and Docker is a nice and common way to achieve that. You can either install Docker Desktop or any alternative of your choice; the only requirement is to be compatible with the Docker buildx command.
How you install Docker is outside the scope of this document; the next step assumes you have it installed and working already.
Step 1: Build the Docker image
To start, we build the Docker image that contains the toolchain, host tools and extra libraries. The Dockerfile can be found here.
Note: please follow the steps for the MOD device you want to build.
Assuming you have Docker installed, you can build it like this:
MOD Duo
docker buildx build \
--build-arg debug=false \
--build-arg target=full \
--build-arg platform="modduo-new" \
/path/to/Plugin-Dev-Setup/docker
MOD Duo X
--build-arg platform="modduox-new" \
MOD Dwarf
--build-arg platform="moddwarf-new" \
The debug argument is optional; the default is "false", but it can be set to "true" if needed. We recommend naming the image with a debug suffix (e.g. --tag "modduo-new-debug", "modduox-new-debug", or "moddwarf-new-debug") to differentiate between release and debug builds easily.
The target argument is also optional, with these possible choices:
full (builds everything: toolchain and all libs) minimal (builds minimal libs only, includes host-cmake, fftw and liblo) kernel (builds libs needed for the Linux kernel) toolchain (builds toolchain only, no extra libs or host tools) The full build will take approximately 1 hour in total, and require around 15Gb of disk space.
You can verify that you have a valid Docker image by running docker images. Your output should contain "modduo-new", "modduox-new", or "moddwarf-new" (according to your device), for example:
MOD Duo
% docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
modduo-new latest 782ca98b7eff 41 minutes ago 14.6GB
MOD Duo X
% docker images
modduox-new latest 782ca98b7eff 41 minutes ago 14.6GB
MOD Dwarf
% docker images
moddwarf-new latest 782ca98b7eff 41 minutes ago 14.6GB
Step 2: Run the Docker image mounted with your local files
After creating a Docker image, we need to create a container based on that image, so we can dynamically run things from it. Because it is a container, it has no direct access to the host filesystem, so we need to map between a folder on the host and the container.
To create a container, run the Docker command like this:
MOD Duo
docker run \
--name "mod-container-name" \
-ti \
-v /path/to/your/project:/root/source \
"modduo-new:latest"
MOD Duo X
docker run \
-ti \
"modduox-new:latest"
MOD Dwarf
docker run \
-ti \
"moddwarf-new:latest"
The --name argument specifies a container name to use; change it to whatever makes more sense for you.
The -ti argument combines t for enabling a "TTY" and i for making it interactive. These 2 arguments together are what allow us to run commands inside the container.
The -v argument specifies a host folder to mount inside the container folder, using ":" as a separator between host and container paths. This argument can be used multiple times to mount multiple folders. The container folder does not need to exist beforehand; Docker creates it as needed.
Finally, the "modduo-new:latest", "modduox:latest", or "moddwarf-new:latest" specifies the image name from which to create the container.
The first time you run this command, you will be dropped into a bash shell inside the container. You can close it at anytime with Ctrl+D. Running it again is possible with docker start -i "mod-container-name" (adjusting name as needed).
Step 3: Build your own project with the custom toolchain
Example using cmake
# setup your project for building (-S specifies cmake project folder, -B specifies build output folder)
cmake -S /path/to/your/project -B build-mod
# build your project
$(which cmake) --build build-mod
NOTE: The odd $(which cmake) above is required; the build environment uses cmake as an alias with a few extra args, which would override --build.
Example using raw makefiles
Simply do:
# build your project (-C specifies the project build folder)
make -C /path/to/your/project
Step 4: Deploy Plugin
If you have mod-sdk installed, start it up using the target plugin dir as LV2_PATH, like so:
$ modsdk
Then open a browser at localhost:9000, select a plugin from the list and use the "deploy" tab to push the selected plugin's bundle to the Duo.
$ cd ~/mod-workdir/plugins/
That's it! Your plugin is now inside the MOD!
