How To Make a MPB Package
Plugin package example
PLUGINPKG_VERSION = 1.0.0
$(eval $(cmake-package))
We're using PLUGINPKG as a generic name, you must use your package name in uppercase here.
Version and download location
If you rather use a git repository, use something like this:
PLUGINPKG_SITE_METHOD = git
LV2 bundles
Use a space to separate the bundle names. Newline escaping is not supported, everything must be in the same line.
PLUGINPKG_BUNDLES = mybundle1.lv2 mybundle2.lv2
Build rules
If you're using autotools or cmake, buildroot has this covered for you already.
autotools
For autotools, use:
$(eval $(autotools-package))
cmake
For cmake, use:
waf
Here's an example for waf:
(cd $(@D); $(PLUGINPKG_TARGET_WAF) configure --prefix=/usr)
endef
define PLUGINPKG_BUILD_CMDS
(cd $(@D); $(PLUGINPKG_TARGET_WAF) build -j $(PARALLEL_JOBS))
endef
(cd $(@D); $(PLUGINPKG_TARGET_WAF) install --destdir=$(TARGET_DIR))
endef
$(eval $(generic-package))
raw makefile
$(PLUGINPKG_TARGET_MAKE)
endef
endef
Tips and tricks
If using autotools or cmake and you need to specify options during configure, use something like this:
PLUGINPKG_CONF_OPTS=-DBUILD_GUI=OFF
If using autotools without an existing 'configure' script (ie, autogen.sh needs to be run first), use this:
PLUGINPKG_AUTORECONF = YES
If using autotools, cmake or raw makefiles and multiple jobs breaks your build, use this:
PLUGINPKG_MAKE = $(MAKE1)
Final notes
A few important notes:
Browse through other examples so you get an idea of variations of project files.
