Control Chain Protocol
About
Physical interface
Protocol
Message Structure
| field | size |
| header | 6 |
| data | N |
Expanding the fields:
| field | subfield | size |
| header | destination | 1 |
| origin | 1 | |
| command | 1 | |
| data size | 2 | |
| check | 1 | |
| data | data 0 | 1 |
| data 1 | 1 | |
| ... | N |
| 0x05 | h | e | l | l | o |
Commands
The valid commands are:
| value | description |
| 0x01 | handshaking |
| 0x02 | device descriptor |
| 0x03 | control assignment |
| 0x04 | data request |
| 0xFF | error report |
Handshaking
Device descriptor
| field | size |
| [none] | 0 |
device to host data field
The masks structure is:
Example:
Control assignment
host to device
device to host
Data request
| field | size |
| [none] | 0 |
Control unassignment
host to device
device to host
| field | size |
| [none] | 0 |
Error report
Operation
