CV Tutorial
Getting Started
Choosing input mode (MOD Duo X only)
  • CV: Use it as a CV input. MOD Duo X CV input/output is unipolar positive, which means it reads/sends signals from 0 to 10V.
Note: The MOD Duo X initial batch units use 5v on their inputs and outputs, even though the values 0-10 are used inside the pedalboard. Second batch of MOD Duo X units (and later) use 10v both in hardware and software, though.
Inputs and outputs on the UI
Basic usage
Example 1
Example 2
Example 3: Standalone Drum Machine
Using CV signals to control any parameter on your pedalboard
Let's see how to do this.
Click the "Manage CV Ports" button at the top of the screen:
2. Assign
3. Advanced Settings
Using CV Parameter Modulation
Following our example, let's:
Example
