Audio Through NetJack2
Jump to navigation
Jump to search
Using netJACK2
sudo ufw allow 19000
Then, ssh into the unit, and run:
touch /data/enable-netmanager
NOTE: You only need to run this command once. The next time the unit boots, jack-netmanager will be loaded by default. Delete the /data/enable-netmanager file inside the unit to remove this auto-start feature.
Now run jackd on your own computer (connected to the unit via USB), like this:
jackd -R -P 80 -d net -a 192.168.51.1 -C 2 -P 2 -i 1 -o 1 -l 4 -n mod-slave -s
Parameters explained
| -a | Multicast address, in this case the IP address of the MOD unit. |
| -C | Number of audio input ports on the slave. This determines the number of audio output ports on the MOD unit, marked as "Hardware Audio To Slave" ports in the web interface. |
| -P | Number of audio output ports on the slave. This determines the number of audio input ports on the MOD unit, marked as "Hardware Audio From Slave" ports in the web interface. |
| -i | Number of MIDI input ports on the slave. This determines the number of MIDI output ports on the MOD unit, marked as "Hardware Midi To Slave" ports in the web interface. |
| -o | Number of MIDI output ports on the slave. This determines the number of MIDI input ports on the MOD unit, marked as "Hardware Midi From Slave" ports in the web interface. |
jack_control dps latency 4
jack_control start
