Control Chain Protocol
This page is a work in progress, the informations here can be modified any time. Please, do not edit it yet, check the discussion section if you'd like to contribute with.
About
Physical interface
Protocol
Message Structure
field size
header 6
data N
Expanding the fields:
field subfield size
header destination 1
origin 1
command 1
data size 2
check 1
data data 0 1
data 1 1
... N
0x05 h e l l o
Commands
The valid commands are:
value description
0x01 handshaking
0x02 device descriptor
0x03 control assignment
0x04 data request
0x05 control unassignment
0xFF error report
Handshaking
field size description
device URI 1B_str a string that identifies the device
channel 1 channel configured on device
protocol version (major) 1 major number version control
protocol version (minor) 1 minor number version control
Device descriptor
field size
[none] 0
device to host data field
field size subfield 1 subfield 2 subfield 3 subfield 4 description
device label 1B_str friendly device name
actuators count 1 amount of actuators of the device
actuators list 1 actuator 1 id actuator id
1B_str name actuator name
1 modes count amount of supported assignment modes
1 modes list mode 1 relevant relevant (mask 1)
1 mandatory mandatory (mask 2)
1B_str label mode label
1 max assignments amount of controls that can be assigned to this actuator
1 steps count amount of values in the steps list
2 steps list value 1 step value 1
2 value 2 step value 2
The masks structure is:
bit 7 bit 6 bit 5 bit 4 bit 3 bit 2 bit 1 bit 0
integer logarithmic toggled trigger scale points enumeration tap tempo bypass
Example:
mode mask integer logarithmic toggled trigger scale points enumeration tap tempo bypass
ON/OFF relevant 0 0 1 1 0 0 0 0
mandatory 0 0 1 0 0 0 0 0
PULSE relevant 0 0 1 1 0 0 0 0
mandatory 0 0 1 1 0 0 0 0
mode mask integer logarithmic toggled trigger scale points enumeration tap tempo bypass mask value
ON/OFF relevant 0 1 1 1 1 1 1 1 0x7F
mandatory 0 0 1 0 0 0 0 0 0x20
PULSE relevant 0 1 1 1 1 1 1 1 0x7F
mandatory 0 0 1 1 0 0 0 0 0x30
TAP TEMPO relevant 1 1 1 1 1 1 1 1 0xFF
mandatory 0 0 0 0 0 0 1 0 0x02
ENUMERATION relevant 0 1 1 1 1 1 1 1 0x7F
mandatory 0 0 0 0 1 1 0 0 0x0C
  • ON/OFF if toggled is implemented but not logarithm, trigger, scale points, enumeration and tap tempo. integer is irrelevant.
  • PULSE if toggled AND trigger are implemented but not logarithm, scale points, enumeration and tap tempo. integer is irrelevant.
  • TAP TEMPO if tap tempo is implemented and no other.
  • ENUMERATION if enumeration AND scale points are implemented but not logarithm, toggled, trigger e tap tempo. integer is irrelevant.
Control assignment
host to device
field size subfield 1 subfield 2 description
actuator id 1 actuator identifier
assignment id 1 assignment identifier
port mask 1 LV2 control port properties
chosen mode 1 relevant relevant (mask 1) of chosen mode
1 mandatory mandatory (mask 2) of chosen mode
label 1B_str control label
value 4 current control value
minimum 4 minimum control value
maximum 4 maximum control value
default 4 default control value
step 2 control step
unit render 1B_str control unit reder
scale points count 1 amount of control scale points
scale points list 1B_str scale point 1 label scale point label
4 value scale point value
device to host
error code 1 indicates whether assignment was well done
Data request
field size
[none] 0
assignments count 1 amount of assignments in the list
assignments list 1 assignment 1 id assignment identifier
4 value current assignment value
Control unassignment
host to device
device to host
field size
[none] 0
Error report
error on command 1 indicates which command raise the error
error code 1 a number that represents the error
error message 1B_str string that describes the error
Operation
See also
