Control Chain Protocol
About
Physical interface
Protocol
Message Structure
field | size |
header | 6 |
data | N |
Expanding the fields:
field | subfield | size |
header | destination | 1 |
origin | 1 | |
command | 1 | |
data size | 2 | |
check | 1 | |
data | data 0 | 1 |
data 1 | 1 | |
... | N |
0x05 | h | e | l | l | o |
Commands
The valid commands are:
value | description |
0x01 | handshaking |
0x02 | device descriptor |
0x03 | control assignment |
0x04 | data request |
0x05 | control unassignment |
0xFF | error report |
Handshaking
field | size | description |
device URI | 1B_str | a string that identifies the device |
channel | 1 | channel configured on device |
protocol version (major) | 1 | major number version control |
protocol version (minor) | 1 | minor number version control |
Device descriptor
field | size |
[none] | 0 |
device to host data field
field | size | subfield 1 | subfield 2 | subfield 3 | subfield 4 | description |
device label | 1B_str | friendly device name | ||||
actuators count | 1 | amount of actuators of the device | ||||
actuators list | 1 | actuator 1 | id | actuator id | ||
1B_str | name | actuator name | ||||
1 | modes count | amount of supported assignment modes | ||||
1 | modes list | mode 1 | relevant | relevant (mask 1) | ||
1 | mandatory | mandatory (mask 2) | ||||
1B_str | label | mode label | ||||
1 | max assignments | amount of controls that can be assigned to this actuator | ||||
1 | steps count | amount of values in the steps list | ||||
2 | steps list | value 1 | step value 1 | |||
2 | value 2 | step value 2 | ||||
The masks structure is:
bit 7 | bit 6 | bit 5 | bit 4 | bit 3 | bit 2 | bit 1 | bit 0 |
integer | logarithmic | toggled | trigger | scale points | enumeration | tap tempo | bypass |
Example:
mode | mask | integer | logarithmic | toggled | trigger | scale points | enumeration | tap tempo | bypass |
ON/OFF | relevant | 0 | 0 | 1 | 1 | 0 | 0 | 0 | 0 |
mandatory | 0 | 0 | 1 | 0 | 0 | 0 | 0 | 0 | |
PULSE | relevant | 0 | 0 | 1 | 1 | 0 | 0 | 0 | 0 |
mandatory | 0 | 0 | 1 | 1 | 0 | 0 | 0 | 0 |
mode | mask | integer | logarithmic | toggled | trigger | scale points | enumeration | tap tempo | bypass | mask value |
ON/OFF | relevant | 0 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 0x7F |
mandatory | 0 | 0 | 1 | 0 | 0 | 0 | 0 | 0 | 0x20 | |
PULSE | relevant | 0 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 0x7F |
mandatory | 0 | 0 | 1 | 1 | 0 | 0 | 0 | 0 | 0x30 | |
TAP TEMPO | relevant | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 0xFF |
mandatory | 0 | 0 | 0 | 0 | 0 | 0 | 1 | 0 | 0x02 | |
ENUMERATION | relevant | 0 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 0x7F |
mandatory | 0 | 0 | 0 | 0 | 1 | 1 | 0 | 0 | 0x0C |
control assignment
host to device
field | size | subfield 1 | subfield 2 | description |
actuator id | 1 | actuator identifier | ||
assignment id | 1 | assignment identifier | ||
port mask | 1 | LV2 control port properties | ||
chosen mode | 1 | relevant | relevant (mask 1) of chosen mode | |
1 | mandatory | mandatory (mask 2) of chosen mode | ||
label | 1B_str | control label | ||
value | 4 | current control value | ||
minimum | 4 | minimum control value | ||
maximum | 4 | maximum control value | ||
default | 4 | default control value | ||
step | 2 | control step | ||
unit render | 1B_str | control unit reder | ||
scale points count | 1 | amount of control scale points | ||
scale points list | 1B_str | scale point 1 | label | scale point label |
4 | value | scale point value | ||
device to host
error code | 1 | indicates whether assignment was well done |
The assignment id is a number that is short way to reference the assignments. It's used in the data request and unassignment commands. The port mask field defines the LV2 control port properties, the mask use the same structure as presented in the device descriptor. The chosen mode is used to device indentify which of your modes has to be applied to this assignment.
Data request
field | size |
[none] | 0 |
assignments count | 1 | amount of assignments in the list | ||
assignments list | 1 | assignment 1 | id | assignment identifier |
4 | value | current assignment value | ||
Control unassignment
host to device
device to host
field | size |
[none] | 0 |
Error report
error on command | 1 | indicates which command raise the error |
error code | 1 | a number that represents the error |
error message | 1B_str | string that describes the error |
Operation
