Control Chain Protocol
About
Physical interface
Protocol
Message Structure
| field | size |
| header | 6 |
| data | N |
Expanding the fields:
| field | subfield | size |
| header | destination | 1 |
| origin | 1 | |
| command | 1 | |
| data size | 2 | |
| check | 1 | |
| data | data 0 | 1 |
| data 1 | 1 | |
| ... | N |
| 0x05 | h | e | l | l | o |
Commands
The valid commands are:
| value | description |
| 0x01 | handshaking |
| 0x02 | device descriptor |
| 0x03 | control assignment |
| 0x04 | data request |
| 0xFF | error report |
Handshaking
device descriptor
| field | size |
| [none] | 0 |
device to host data field
The masks structure is:
Example:
control assignment
host to device
device to host
The assignment id is a number that is short way to reference the assignments. It's used in the data request and unassignment commands. The port mask field defines the LV2 control port properties, the mask use the same structure as presented in the device descriptor. The chosen mode is used to device indentify which of your modes has to be applied to this assignment.
data request
| field | size |
| [none] | 0 |
host to device
device to host
| field | size |
| [none] | 0 |
error report
Operation
