Control Chain Protocol
About
Control Chain is an open hardware assignment protocol developed to reflect the LV2 controls properties. In other words the Control Chain able you to control LV2 plugins control ports using a hardware device like Arduino.
Although the Control Chain has been created focused on MOD, it isn't a must to has it working with LV2 plugins. This can be done using, for example, an Arduino, connected via USB to your PC.
This page concentrates technical informations of Control Chain. If you are looking for startup guide to create new controllers, please refer to MOD Arduino Shield article, there you will find a tutorial and Arduino cases that will help you.
Physical interface
Protocol
Message Structure
| field | size |
| header | 6 |
| data | N |
Expanding the fields:
| field | subfield | size |
| header | destination | 1 |
| origin | 1 | |
| command | 1 | |
| data size | 2 | |
| check | 1 | |
| data | data 0 | 1 |
| data 1 | 1 | |
| ... | N |
| 0x05 | h | e | l | l | o |
Commands
The valid commands are:
| value | description |
| 0x01 | handshaking |
| 0x02 | device descriptor |
| 0x03 | control assignment |
| 0x04 | data request |
| 0xFF | error report |
handshaking
Devices can only send the handshaking to host when the host isn't sending data. New devices doesn't has any origin address yet thus the origin, in the header message field, must contain the 0x00 value. Once that host received the handshaking it will generate an address to new device, this address value must be between 0x80 and 0xFF, inclusively, and must be informed to device using the destination field. The data field of original message must be give back to device untouched, allowing the device discover its address.
device descriptor
| field | size |
| [none] | 0 |
device to host data field
The masks structure is:
Example:
control assignment
host to device
device to host
The assignment id is a number that is short way to reference the assignments. It's used in the data request and unassignment commands. The port mask field defines the LV2 control port properties, the mask use the same structure as presented in the device descriptor. The chosen mode is used to device indentify which of your modes has to be applied to this assignment.
data request
| field | size |
| [none] | 0 |
host to device
device to host
| field | size |
| [none] | 0 |
error report
Operation
