Control Chain Protocol
About
Control Chain is an open hardware assignment protocol developed to reflect the LV2 controls properties. In other words the Control Chain able you to control LV2 plugins control ports using a hardware device like Arduino.
Although the Control Chain has been created focused on MOD, it isn't a must to has it working with LV2 plugins. This can be done using, for example, an Arduino, connected via USB to your PC.
This page concentrates technical informations of Control Chain. If you are looking for startup guide to create new controllers, please refer to MOD Arduino Shield article, there you will find a tutorial and Arduino cases that will help you.
Physical interface
Protocol
Message Structure
| field | size |
| header | 6 |
| data | N |
Expanding the fields:
| field | subfield | size |
| header | destination | 1 |
| origin | 1 | |
| command | 1 | |
| data size | 2 | |
| check | 1 | |
| data | data 0 | 1 |
| data 1 | 1 | |
| ... | N |
Commands
The valid commands are:
| value | description |
| 0x01 | handshaking |
| 0x02 | device descriptor |
| 0x03 | control assignment |
| 0x04 | data request |
| 0xFF | error report |
handshaking
Devices can only send the handshaking to host when the host isn't sending data. New devices doesn't has any origin address yet thus the origin, in the header message field, must contain the 0x00 value. Once that host received the handshaking it will generate an address to new device, this address value must be between 0x80 and 0xFF, inclusively, and must be informed to device using the destination field. The data field of original message must be give back to device untouched.
device descriptor
host to device
| field | size |
| [none] | 0 |
device to host
| 1 | modes list | mode 1 | mask 1 | property mask 1 | ||
| 1 | mask 2 | property mask 2 | ||||
| 1 | slots | amount of controls that can be assigned to this actuator | ||||
control assignment
host to device
| chosen mode | 1 | mask 1 | mask 1 of chosen mode | |
| 1 | mask 2 | mask 2 of chosen mode | ||
device to host
| response status | 2 | indicates whether assignment was well done |
data request
host to device
| sequence | 1 | sequential number used to detect non answered messages |
device to host
host to device
device to host
| field | size |
| [none] | 0 |
error report
Operation
The host start to polling the identified devices for data request as soon as an assignement is done. The polling period is determinated by the host considering the count of identified devices. In each polling devices cycle the host is responsible to reserve a short period of time to allow that new devices connect to it or send other requests, this because devices can only send messages to host when it isn't sending any message.
The host can control when the devices will message it keeping its transmission line sending data.
