Control Chain Protocol
About
Control Chain is an open hardware assignment protocol developed to reflect the LV2 controls properties. In other words the Control Chain able you to control LV2 plugins control ports using a hardware device like Arduino.
Although the Control Chain has been created focused on MOD, it isn't a must to has it working with LV2 plugins. This can be done using, for example, an Arduino, connected via USB to your PC.
This page concentrates technical informations of Control Chain. If you are looking for startup guide to create new controllers, please refer to MOD Arduino Shield article, there you will find a tutorial and Arduino cases that will help you.
Physical interface
Protocol
Message Structure
| field | size |
| header | 5 |
| data | N |
| check | 1 |
The header contain the following informations: destination, origin, command and data size. The data field holds the data bytes related to command. And the check is the byte message verification. It's calculated XOR'ing all message bytes.
Expanding the fields:
| field | subfield | size |
| header | destination | 1 |
| origin | 1 | |
| command | 1 | |
| data size | 2 | |
| data | data 0 | 1 |
| data 1 | 1 | |
| ... | N | |
| check | 1 |
The destination and origin fields are addresses that says from where the message is going to and coming from, respectively. The value 0x00 stands for the host address and the devices addresses values must be between 0x80 and 0xFF, inclusively.
Commands
The valid commands are:
| value | description |
| 0x01 | handshaking |
| 0x02 | device descriptor |
| 0x03 | control assignment |
| 0x04 | data request |
| 0xFF | error report |
handshaking
device to host or host to device
device descriptor
host to device
| field | size |
| [none] | 0 |
device to host
| 1 | modes list | mode 1 | mask 1 | property mask 1 | ||
| 1 | mask 2 | property mask 2 | ||||
| 1 | slots | amount of controls that can be assigned to this actuator | ||||
control assignment
host to device
| chosen mode | 1 | mask 1 | mask 1 of chosen mode | |
| 1 | mask 2 | mask 2 of chosen mode | ||
device to host
| response status | 2 | indicates whether assignment was well done |
data request
host to device
| sequence | 1 | sequential number used to detect non answered messages |
device to host
host to device
device to host
| field | size |
| [none] | 0 |
error report
Operation
The host start to polling the identified devices for data request as soon as an assignement is done. The polling period is determinated by the host considering the count of identified devices. In each polling devices cycle the host is responsible to reserve a short period of time to allow that new devices connect to it or send other requests, this because devices can only send messages to host when it isn't sending any message.
The host can control when the devices will message it keeping its transmission line sending data.
