Control Chain Protocol
Revision as of 21:35, 22 October 2014 by Crudo (talk | contribs)
This page is in a work in progress, the informations here can be modified any time. Please, do not edit it yet, check the discussion section if you'd like to contribute with.
About
Control Chain is an open hardware assignment protocol developed to reflect the LV2 controls properties. In other words the Control Chain able you to control LV2 plugins control ports using a hardware device like Arduino.
Although the Control Chain has been created focused on MOD, it isn't a must to has it working with LV2 plugins. This can be done using, for example, an Arduino, connected via USB to your PC.
This page concentrates technical informations of Control Chain. If you are looking for startup guide to create new controllers, please refer to MOD Arduino Shield article, there you will find a tutorial and Arduino cases that will help you.
Physical interface
Protocol
Message Structure
field size
header 5
data N
check 1
The header contain the following informations: destination, origin, command and data size. The data field holds the data bytes related to coommand. And the check is the message verification byte. It's calculated XOR'ing all message bytes.
Expanding the fields:
field subfield size
header destination 1
origin 1
command 1
data size 2
data data 0 1
data 1 1
... N
check 1
The destination and origin fields are addresses that says from where the message is going to and coming from, respectively. The value 0x00 stands for the host address and the devices addresses values must be between 0x80 and 0xFF, inclusively.
Commands
The valid commands are:
value description
0x01 handshaking
0x02 device descriptor
0x03 control assignment
0x04 data request
0x05 control unassignment
0xFF error report
handshaking
device to host or host to device
field size description
device URI 1B_str a string that identifies the device
channel 1 channel configured on device
protocol version (major) 1 major number version control
protocol version (minor) 1 minor number version control
device descriptor
host to device
field size
[none] 0
device to host
field size subfield 1 subfield 2 subfield 3 subfield 4 description
device label 1B_str friendly device name
actuators count 1 amount of actuators of the device
actuators list 1 actuator 1 id actuator id
1B_str name actuator name
1 modes count amount of supported assignment modes
1 modes list mode 1 mask 1 property mask 1
1 mask 2 property mask 2
1B_str label mode label
1 slots amount of controls that can be assigned to this actuator
1 steps count amount of values in the steps list
2 steps list value 1 step value 1
2 value 2 step value 2
control assignment
host to device
field size subfield 1 subfield 2 description
actuator id 1 actuator identifier
assignment id 1 assignment identifier
port mask 1 LV2 control port properties
chosen mode 1 mask 1 mask 1 of chosen mode
1 mask 2 mask 2 of chosen mode
label 1B_str control label
value 4 current control value
minimum 4 minimum control value
maximum 4 maximum control value
default 4 default control value
step 2 control step
unit render 1B_str control unit reder
scale points count 1 amount of control scale points
scale points list 1B_str scale point 1 label scale point label
4 value scale point value
device to host
response status 2 indicates whether assignment was well done
data request
host to device
sequence 1 sequential number used to detect non answered messages
device to host
assignments count 1 amount of assignments in the list
assignments list 1 assignment 1 id assignment identifier
4 value current assignment value
host to device
device to host
field size
[none] 0
error report
error on command 1 indicates which command raise the error
error code 1 a number that represents the error
error message 1B_str string that describes the error
Operation
Initially host is waiting for devices handshaking, once the first device sends the handshaking, the host must response back informing its device id. After that host must request the device descriptor and wait for device response or timeout. Since the device is identified on host, it should wait until the host send to it an assignment request.
The host start to polling the identified devices for data request as soon as an assignement is done. The polling period is determinated by the host considering the count of identified devices. In each polling devices cycle the host is responsible to reserve a short period of time to allow that new devices connect to it, this because devices can only send messages to host when it isn't sending any message.
The host can control when the devices will message it keeping its transmission line sending data.
