Control Chain Protocol
Revision as of 20:58, 16 September 2014 by Crudo (talk | contribs)
About
MOD Arduino Shield
Brief description. To do.
Main article: MOD Arduino Shield
MOD Arduino Cases
  • Accelerometer
Control any effect parameter using an accelerometer. Control up to six parametera using the six degrees of freedom, three axis acceleration and three axis rotation.
Main article: Arduino Case: Accelerometer
  • Distance
Control any effect parameter using an ultrasound distance sensor.
Main article: Arduino Case: Distance Sensor
  • Expression Pedal
Control any effect parameter using an expression pedal. Not only the usual wah-wah pedal - you can control tune, frequency, gain just like if you were changing a potenciometer value. Cames with an extra button for bypass, trigger or toggle effects/parameters.
Main article: Arduino Case: Expression Pedal
  • Footswitch
Control and switch parameteres using a footswitch. Expand your MOD by adding four extra footswitches.
Main article: Arduino Case: Footswitch
  • Light Sensor
Control any effect parameter using a light sensor. The change of light will change the sound.
Main article: Arduino Case: Light Sensor
