Audio Through USB
Using USB Audio Gadget
NOTE: For best results, please use v1.14 or later
NOTE: This is EXPERIMENTAL
touch /data/enable-usb-multi-gadget touch /data/enable-usb-audio-gadget
If using Windows, also run:
touch /data/enable-usb-windows-compat
Now we reboot:
sync && hmi-reset && reboot
Some caveats and known issues:
- USB audio requires very precise timings, loading big resources on the web interface over USB can lead to audio dropouts (best results are achieved with the web interface over WiFi, leaving USB for audio and MIDI)
Forum Threads:
Windows-specific tweaks
When picking an audio driver/mode, look for "WASAPI" or "Windows Audio".
If there is an option for "exclusive mode", try that first; it won't allow other applications to use the USB audio device at the same time, but it reduces the latency.
Using this WASAPI/Windows-Audio mode with a 512 buffer size, we have measured round-trip latencies of around 80ms in normal/shared mode, and 60ms in exclusive mode.
When exclusive mode is selected, we were able to reducethe buffer size to 256, giving a round-trip latency of around 38ms.
Note that latency decreases if you use the MOD device analog IO, as the analog IO has a full round-trip latency of 8ms.
There is extra buffering for handling the USB audio card in software, which is needed in order to keep everything in sync between the MOD device's main audio interface and the USB audio side.
ASIO4ALL
Using ASIO4ALL has been confirmed to work, but needs some tweaks:
- In advanced settings, set buffer offset to 16ms
This should result in around 60ms total round-trip latency, which will be less if you use the MOD unit analog IO.
FL Studio ASIO
The FL Studio ASIO driver has also been confirmed to work, no special tweaks needed.
Its minimum buffer size of 256 should work fine as-is.
In our measurements, it gives a total round-trip latency of around 75ms, which will be less if you use the MOD unit analog IO.
Using netJACK2
