MOD Duo X User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CV Input
Headphone/CV Output
SPDIF out
The S/PDIF output on the MOD Duo X is a digital output that can be used either to mirror the two audio outputs or to have two extra digital outputs. You can connect it to your audio interface.
Left endless knob actions
Right endless knob actions
Performance buttons
Instant snapshots
Pagination
Left Display
Right Display
- width: 163 mm
- length: 188 mm
- height: 63 mm
The MOD Duo X allows you to switch between 3 pages of settings. This means that the 8 knobs, 2 endless knobs and 4 buttons are actually 24 knobs, 6 endless knobs and 12 buttons. When you address a plugin parameter to a MOD Duo X actuator, you can choose which page you want to address the parameter to.
The pagination button is the central button of the 3 top buttons in the MOD Duo X panel. Its light indicates the current selected page:
- 1st page: red
- 2nd page: yellow
- 3rd page: green
