MOD Dwarf Technical Specs
Revision as of 08:54, 30 September 2025 by Joao.sensiguitar (talk | contribs) (→‎Audio)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
The MOD Dwarf when powered up
Technical specs
  • length: 105 mm
  • width: 202 mm
  • height: 54 mm
Processor
  • RockChip PX30 CPU:
    • CPU family: Cortex-A35
    • Platform bit depth: 64 bit
    • Cores Clock: 4 x (up to) 1.3 GHz
    • Memory: 1 GB RAM
    • Flash Storage: 8 GB
Audio
MOD Dwarf back view showing all its ports.
  • 2x independent mono audio inputs with:
    • Unbalanced asymmetrical TRS connection
    • input adjustment between -12dB and +35dB, adjustable in 0.5dB steps
    • Input impedance 1 MΩ
  • 2x independent mono audio outputs with:
    • Balanced symmetrical TRS connection
    • Volume Control: 0dB to -127dB, adjustable in 0.5dB steps
  • Headphone output:
    • 3.5mm TRS Stereo connection
    • 2x105mW @ 16 ohms
    • Mirrors main output
    • Digital volume control from -33dB to +12dB, adjustable in 3dB steps
USB
  • USB Host
    • Connector: Type-A
    • Standard: USB 2.0
  • USB Device
    • Connector: Type-B
    • Standard: USB 2.0
Device Controller
  • 1x 2.9" LCD display
  • 3x endless knobs
  • 3x push buttons (backlit with colour LEDs)
  • 1x menu button (backlit with colour LEDs)
  • 3x footswitches with coloured indicator LEDs
Software
The MOD Dwarf runs the latest Operating System. Support for the MOD Dwarf was added to the MOD OS on version 1.10.
