Audio Through USB
Using USB Audio Gadget
NOTE: This is EXPERIMENTAL
touch /data/enable-usb-multi-gadget touch /data/enable-usb-audio-gadget # if using windows, also run: touch /data/enable-usb-windows-compat
Now we reboot
sync && hmi-reset && reboot
Some caveats and known issues:
Forum Threads:
Windows specific tweaks
When picking an audio driver/mode look for "WASAPI" or "Windows Audio".
If there is an option for "exclusive mode" try that first; it won't allow other applications to use the usb audio device at the same time but it reduces the amount of latency.
Under this WASAPI/Windows-Audio mode with 512 buffer size we have measure roundtrip latencies of around 80ms in normal/shared mode, and 60ms in exclusive mode.
When exclusive mode is selected we were able to reduce buffer size to 256, giving a roundtrip latency of around 38ms.
Note that latency decreases if you use the MOD unit analog IO, as the analog IO has a full roundtrip latency of 8ms.
There is extra buffering for handling the USB audio card in software, which is needed in order to keep everything in sync between the MOD unit main audio interface and the USB audio side.
ASIO4ALL
Using ASIO4ALL has been confirmed to work, but needs some tweaks:
- In advanced settings set buffer offset to 16ms
FL Studio ASIO
The FL Studio ASIO driver has also been confirmed to work, no special tweaks needed.
Its minimum buffer size of 256 should work fine as-is.
In our measurements it gives a total roundtrip latency of around 75ms, will be less if you use the MOD unit analog IO.
Using netJACK2
