Audio Through NetJack2
Revision as of 09:07, 26 July 2023 by FalkTX (talk | contribs) (Created page with "== Using netJACK2 == '''NOTE: This requires the use of JACK as sound server in your PC.''' First, connect the MOD unit to your PC via usb cable. Make sure to open port 19000...")
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Using netJACK2
sudo ufw allow 19000
Then, ssh into the unit, and run:
touch /data/enable-netmanager
NOTE: You only need to run this command once. The next time the unit boots, jack-netmanager will be loaded by default. Delete the /data/enable-netmanager file inside the unit to remove this auto-start feature.
Now run jackd on your own computer (connected to the unit via USB), like this:
jackd -R -P 80 -d net -a 192.168.51.1 -C 2 -P 2 -i 1 -o 1 -l 4 -n mod-slave -s
Parameters explained
-R Use realtime scheduling, enabled by default.
-P Set the realtime scheduling priority, in this case 80.
-d JACK backend, in this case the "net" driver.
-a Multicast address, in this case the IP address of the MOD unit.
-C Number of audio input ports on the slave. This determines the number of audio output ports on the MOD unit, marked as "Hardware Audio To Slave" ports in the web interface.
-P Number of audio output ports on the slave. This determines the number of audio input ports on the MOD unit, marked as "Hardware Audio From Slave" ports in the web interface.
-i Number of MIDI input ports on the slave. This determines the number of MIDI output ports on the MOD unit, marked as "Hardware Midi To Slave" ports in the web interface.
-o Number of MIDI output ports on the slave. This determines the number of MIDI input ports on the MOD unit, marked as "Hardware Midi From Slave" ports in the web interface.
-l Number of cycles, determines the network latency.
-s Setting this option makes the JACK slave memorize the ports that are connected to the JACK master. In case the master disappears and reappears the JACK slave will try to reconnect those ports automatically.
jack_control dps latency 4
jack_control start
