How To Use Docker Toolbox With MPB
Pre-compiled image
Some notes:
$ docker start -i mpb
To create a Duo image run:
$ docker build -t mpb --build-arg platform=modduo .
Or to create a Duo X image run:
$ docker build -t mpb --build-arg platform=modduox .
Or to create a Dwarf image run:
$ docker build -t mpb --build-arg platform=moddwarf .
NOTE: This will take quite some time...
$ exit
Docker on an Apple M1 system to build Dwarf plugins
These are the steps to get the MOD plugin builder setup on an Apple M1 system.
Docker Docker Desktop 4.21.1 (114176)  All settings default
cd ~
mkdir dwarf
cd dwarf
docker build -t mpb --build-arg platform=moddwarf-new .
This results in
Executing
cd ..
./docker-mount.sh moddwarf-new mpb
will fire up an interactive Docker terminal
builder@02f246028ba5:~/mod-plugin-builder$
In this Docker machine, run
git submodule init
git submodule update
And then in the Docker machine, you can perform builds, such as
./build moddwarf-new abgate
./build moddwarf-new guitarix
./build moddwarf-new x42-midifilter
Back in the MacOS world, you should be able to see the LV2 files on your drive.
