How To Use Docker Toolbox With MPB
Pre-compiled image
To create a Duo image run:
Docker on an Apple M1 system
These are the steps to get the MOD plugin builder setup on an Apple M1 system.
cd ~
mkdir dwarf
cd dwarf
Executing
cd ..
git submodule init
./build moddwarf-new abgate
./build moddwarf-new guitarix
