How To Use Docker Toolbox With MPB
Pre-compiled image
Some notes:
$ docker start -i mpb
To create a Duo image run:
$ docker build -t mpb --build-arg platform=modduo .
Or to create a Duo X image run:
$ docker build -t mpb --build-arg platform=modduox .
Or to create a Dwarf image run:
$ docker build -t mpb --build-arg platform=moddwarf .
NOTE: This will take quite some time...
$ exit
Docker on an Apple M1 system
These are the steps to get the MOD plugin builder setup on an Apple M1 system.
cd ~
mkdir dwarf
cd dwarf
docker build -t mpb --build-arg platform=moddwarf-new .
This results in
Checking in the Docker gui you should see a new image mpb.
Executing
cd ..
./docker-mount.sh moddwarf-new mpb
will fire up an interactive Docker terminal
builder@02f246028ba5:~/mod-plugin-builder$
In this Docker machine, run
git submodule init
git submodule update
And then in the Docker machine, you can perform builds, such as
./build moddwarf-new abgate
./build moddwarf-new guitarix
./build moddwarf-new x42-midifilter
Back in the MacOS world, you should be able to see the LV2 files in you
