How To Use Docker Toolbox With MPB
Pre-compiled image
To create a Duo image run:
Docker on an Apple M1 system
These are the steps to get the MOD plugin builder setup on an Apple M1 system. This was tested in July-2023 on the following system Host MacBook Pro 13-inch, M1, 2020 16Gb Memory macOS 13.4.1 (22F82)
cd ~
mkdir dwarf
cd dwarf
Checking in the Docker gui you should see a new image mpb.
Executing
cd ..
git submodule init
./build moddwarf-new abgate
./build moddwarf-new guitarix
./build moddwarf-new x42-midifilterBack in the MacOS world, you should be able to see the LV2 files in you
