How To Use Docker Toolbox With MPB
Pre-compiled image
To create a Duo image run:
Docker on an Apple M1 system
These are the steps to get the MOD plugin builder setup on an Apple M1 system. This was tested on Host MacBook Pro 13-inch, M1, 2020 16Gb Memory macOS 13.4.1 (22F82)
cd ~
mkdir dwarf
cd dwarf
docker build -t mpb --build-arg platform=moddwarf-new .
This results in
Checking in the Docker gui you should see a new image mpb.
``` cd .. ./docker-mount.sh moddwarf-new mpb ``` Fires up an interactive Docker terminal ``` builder@02f246028ba5:~/mod-plugin-builder$ ``` In this Docker machine, run ``` git submodule init git submodule update ``` And then in the Docker machine, you can perform builds, such as ``` ./build moddwarf-new abgate ./build moddwarf-new portal-lv2 ./build moddwarf-new guitarix ./build moddwarf-new x42-midifilter ```
Back in the MacOS world, you should be able to see the LV2 files in you
