Factory Reset Images
Jump to navigation
Jump to search
Release links
MOD Duo: modduo-v1.13.2.3175.tar
MOD Duo X: modduox-v1.13.2.3176.tar
MOD Dwarf: moddwarf-v1.13.2.3177.tar
- Enter the settings menu
