How To Use Docker Toolbox With MPB
Pre-compiled image
$ cd mod-plugin-builder/dockerAfter that, you can choose to either create an image for compiling plugins for the DUO, the DUO X, or the DWARF. All the platforms available are: modduo, modduo-debug, modduo-new, modduo-new-debug, modduo-static, modduox, modduox-debug, modduox-new, modduox-new-debug, modduox-static, moddwarf, moddwarf-debug, moddwarf-new, moddwarf-new-debug, raspberrypi4, x86_64 & x86_64-debug.
To create a Duo image run:
