Building a plugin for MOD Duo and MOD Duo X
LV2 Basics
This information is well described elsewhere. The SDK assumes that you have a working lv2 plugin for desktop linux. If you haven't gotten that far, you should start with these links:
Prepare build tools
This section needs to be updated with DuoX information
In order to run a plugin in the MOD Duo we must compile it for its specific architecture.
The Duo uses an ARMv7 processor running a very basic and stripped-down version of Linux.
Several audio-related libraries are included (fftw, libsndfile, libresample, etc) as well as generic libraries (boost, eigen, qt5core, etc).
We currently provide a custom build system that gives developers a similar system to what's available inside the Duo.
Do not use a regular Linux system, it might lead to issues due to mismatching library versions.
In summary:
$ cd mod-plugin-builder
$ ./bootstrap.shThis process should take at least 1 hour, probably more depending on your CPU. When it finishes you'll be able to build plugins for Duo.
Using docker
Alternatively, if you're familiar with docker or are not running Linux, you can also use our mod-plugin-builder image which includes an already built system.
See this HowTo for more information about docker and mod-plugin-builder.
Build using buildroot '.mk' files
In order to publish your plugin in Mod Labs cloud, you need to use buildroot. See this guide on how to use buildroot to build plugins.
Local development
For local development of plugins using buildroot can be bothersome and confusing.
You can use the cross-compiler and toolchain directly instead of going through buildroot methods.
Note that this expects that your source code build system is cross-compile friendly (ie, no hardcoded compiler and paths and uses pkg-config to find extra libraries).
Also this only works on a real Linux system, without using docker.
The setup is as simple as: (adjust as needed)
$ . ~/mod-plugin-builder/local.env
Quick example plugin
A quick example plugin is available inside mod-plugin-builder in make -C plugins/package/eg-amp-lv2/source/, which works with this cross-compilation setup.
See https://github.com/moddevices/mod-plugin-builder/tree/master/plugins/package/eg-amp-lv2-labs/source
Building this example plugin is as simple as:
$ make -C ~/mod-plugin-builder/plugins/package/eg-amp-lv2/sourceThat's it! After this the eg-amp.lv2 bundle is ready to be deployed into a MOD unit.
