Max gen~
Revision as of 18:36, 18 March 2023 by Zwabo (talk | contribs)
Apart from programming LV2-plugins in a "traditional" way, it's also possible to generate LV2-plugins for MOD devices from gen~ objects created in Cycling '74 Max.
Gen basics
Designing your effect in Gen
  • To get your gen~ object working on a MOD device, you'll need to design one using only Gen's internal objects, without referring to objects outside the gen~ object.
    Only the objects inside will make it to the final LV2-plugin.
  • If you want controllable parameters, define the default, minimum and maximum arguments in the "param" object.
  • While designing your gen~ object, remember that all MOD devices are running at 48 kHz sampling rate.
Getting your Gen-based plugin to a MOD device
At this point you should have met the requirements specified above. If so, follow the steps below to get your plugin on a MOD device.
In order to run Gen-based plugins on a MOD device they must be converted into LV2 plugins and compiled using a custom MOD cloud build system.
  • Go to or install the MOD Duo-package in the Package Manager in Max if you haven't, and click on Launch.
  • Make sure your MOD device is connected, then start the MODwatcher from the popped-up screen.
  • If you want your plugin to have a name, copy your gen~ objects contents to a gen~ object with a patcher-name argument.
    WARNING: naming your original gen~ object will initialize it's contents.
  • Finally send a message containing "exportnotifier MODwatcher, exportcode" (without the quotation marks) to the gen~ object.
Your plugin will now be transferred to the MOD device, within a few minutes the MODwatcher will tell you if the upload succeeded.
Your Gen-based will only show knobs for each parameter. To get switches, selector, etc.. you’ll have to edit the .ttl file and add/change a few lines.
On a Mac you can do this with the nano editor:
  • Open up Terminal
  • Enter
$ ssh root@192.168.51.1
  • Password
$ mod
  • Enter
$ .lv2/YOURPLUGIN_NAME.lv2/YOURPLUGIN_NAME_dsp.ttl
i.e. to get a switch for this parameter:
a lv2:InputPort ,
        lv2:ControlPort ;
       lv2:index 5 ;
       lv2:symbol “FILTER” ;
       lv2:name “FILTER” ;
       lv2:default 0 ;
       lv2:minimum 0 ;
       lv2:maximum 1 ;
  • Add this line : lv2:portProperty lv2:integer, lv2:toggled  ;
which gives:
a lv2:InputPort ,
        lv2:ControlPort ;
       lv2:index 5 ;
       lv2:name “FILTER” ;
       lv2:default 0 ;
       lv2:minimum 0 ;
       lv2:maximum 1 ;
i.e if you want the host/mod tempo to control a time parameter
  • Add this line to the prefix list (at the beginning of the file):
@prefix  time: <http://lv2plug.in/ns/ext/time#> .
  • and these lines to the time Control Port which will give:
lv2:ControlPort ;
       lv2:index 2 ;
       lv2:symbol "BPM" ;
       lv2:name "BPM" ;
       lv2:default 120 ;
       lv2:minimum 24 ;
       lv2:maximum 280 ;
       units:unit units:bpm ;
       lv2:portProperty  mod:tempoRelatedDynamicScalePoints;
i.e if you want a selector
@prefix rdf: <http://www.w3.org/1999/02/22-rdf-syntax-ns#> .
And change i.e. this:
a lv2:InputPort, lv2:ControlPort ;
       lv2:index 6 ;
       lv2:name "Div_L" ;
       lv2:symbol "Div_L" ;
       lv2:default 1.000000 ;
       lv2:minimum 1.000000 ;
       lv2:maximum 5.000000 ;
To this :
       lv2:index 6 ;
       lv2:name "Div" ;
       lv2:symbol "Div" ;
       lv2:default 1.0 ;
       lv2:minimum 1.0 ;
       lv2:maximum 5.0 ;
       lv2:portProperty lv2:integer;
       lv2:portProperty lv2:enumeration ;
       lv2:scalePoint [rdfs:label "1/4note"; rdf:value 1];
       lv2:scalePoint [rdfs:label "Dotted1/8note"; rdf:value 2];
       lv2:scalePoint [rdfs:label "1/4notetriplets"; rdf:value 3];
       lv2:scalePoint [rdfs:label "1/8note"; rdf:value 4];
       lv2:scalePoint [rdfs:label "1/8notetriplets"; rdf:value 5];
  • When you’re done, exit nano:
Ctrl + x
  • select Y(yes) or N (no)
  • Enter
systemctl restart mod-ui
  • Enter
exit
If all goes well, your modified Gen-based plugin should now be inside the MOD device, ready to be played!
Alternatively
There is another process which is different from the process described above. It doesn't use the MOD Duo-package in Max.
Compiling the plugin
First, download https://download.moddevices.com/releases/max-gen/max-gen-deploy_v6.tar.gz and extract it.
Send an "exportcode" message to the gen~ object in your main Max-patcher to get the YOURPLUGIN_NAME.cpp and YOURPLUGIN_NAME.h files.
replace YOURPLUGIN_NAME with “gen_exported" for both files Copy the gen_exported.cpp and gen_exported.h files into the extracted max-gen-deploy folder, and run:
$ cd /path/to/max-gen-deploy/
$ ./mod-build.sh
Editing the plugin
To add units, knob behavior or a description, you'll have to edit the .ttl file. If you do so, make sure everything is correct,
OPTIONAL
$ tar -xzvf Plugin.lv2-dwarf.tar.gz
$ rm Plugin.lv2-dwarf.tar.gz
Deploying the plugin
$ ./mod-deploy.sh
