How To Use Docker Toolbox With MPB
Pre-compiled image
Some notes:
$ docker start -i mpb
To create a Duo image run:
$ docker build -t modduo-plugin-builder --build-arg platform=modduo .
Or to create a Duo X image run:
$ docker build -t modduox-plugin-builder --build-arg platform=modduox .
Or to create a Dwarf image run:
$ docker build -t moddwarf-plugin-builder --build-arg platform=moddwarf .
NOTE: This will take quite some time...
$ exit
