| 1.13 | 2023/02/27 | Separation of User vs Factory content; Update base toolchain; Add Bluetooth + WiFi firmware | Duo: modduo-v1.13.0.3089.tar Duo X: modduox-v1.13.0.3090.tar |
- 3 Release 1.13
- 4 Release 1.12
- 5 Release 1.11
- 6 Release 1.10
- 7 Release 1.9
- 8 Release 1.8
- 9 Release 1.7
- 10 Release 1.6
- 11 Release 1.5
- 12 Release 1.4
- 13 Release 1.3
- 14 Release 1.2
- 15 Release 1.1
- 16 Release 1.0
- 17 Release 0.15.0
- 18 Release 0.14.0
- 19 Release 0.13.0
- 20 Release 0.12.2
- 21 Release 0.11.3
- 22 Release 0.10.4
- 23 Release 0.9.0
Release 1.13
v1.13.0
Released on 2023/02/27
v1.13-RC1
Released on 2023/02/13
- Speed up pedalboard listing
- Update base compiler and toolchain to gcc9 and glibc2.38
Dwarf specific:
Release 1.12
v1.12.2
Released on 2023/01/17
v1.12.1
Released on 2022/12/21
v1.12.0
Released on 2022/12/01
- fix memory leaks
Duo X specific changes:
v1.12-RC3
Released on 2022/07/05
v1.12-RC2
Released on 2022/06/08
Duo X specific:
Dwarf specific:
v1.12-RC1
Released on 2022/05/20
- many system tweaks
Duo X specific: (all units)
Dwarf specific:
- NEW: LED brightness option
v1.11.6
v1.11.5
Released on 2022/05/05
v1.11.4
Released on 2022/04/08
Dwarf specific (device side):
v1.11.3
Released on 2022/03/11
- add "/allguis" special page
Dwarf specific:
v1.11.2
Released on 2022/02/11
Duo X specific:
Dwarf specific:
v1.11.1
Released on 2022/01/28
Dwarf specific:
v1.11.0
Released on 2021/12/23
Released on 2021/12/17
Released on 2021/11/16
- NEW: Virtual MIDI Loopback
- Add button color for banks
- New MOD Dwarf logo
- Add opus audio file support
