Revision as of 17:47, 13 February 2023 by FalkTX (talk | contribs) (→‎Release 1.13)
Stable Releases
Duo X: modduox-v1.7.4.855.tar
  1. Turn on your MOD
Release 1.13
v1.13.0
Work-in-progress!
  • Add a few handy modgui javascript utilities (get_custom_resource_filename, get_port_index_for_symbol, get_port_symbol_for_index), bump API version to 3
  • Add plugin-specific "aidadspmodel" file type
  • Add Bluetooth and WiFi firmware
  • Adjust UAC2 gadget name and buffering details
  • Allow to privately share a pedalboard (new checkbox in share dialog)
  • Allow "see discussion" button on plugin information dialogs
  • Fix Duo name in Duo X and Dwarf zeroconf service names
  • Fix pedalboard screenshot generation
  • Log exceptions thrown by modgui javascript code
  • Speed up pedalboard listing
  • Send "end" event to modguis just before deletion
  • Update Duo and Dwarf kernel to 6.1.7
  • Update base compiler and toolchain to gcc9 and glibc2.38
Dwarf specific:
  • NEW: Split factory and user pedalboards and banks
  • Auto-delete banks.json and pedalboards in user data when they match factory content
  • System-level tweaks to make CPU load more consistent
Release 1.12
v1.12.2
Released on 2023/01/17
v1.12.1
Released on 2022/12/21
v1.12.0
Released on 2022/12/01
  • fix memory leaks
Duo X specific changes:
v1.12-RC3
Released on 2022/07/05
v1.12-RC2
Released on 2022/06/08
Duo X specific:
Dwarf specific:
v1.12-RC1
Released on 2022/05/20
  • many system tweaks
Duo X specific: (all units)
Dwarf specific:
  • NEW: LED brightness option
v1.11.6
v1.11.5
Released on 2022/05/05
v1.11.4
Released on 2022/04/08
Dwarf specific (device side):
v1.11.3
Released on 2022/03/11
  • add "/allguis" special page
Dwarf specific:
v1.11.2
Released on 2022/02/11
Duo X specific:
Dwarf specific:
v1.11.1
Released on 2022/01/28
Dwarf specific:
v1.11.0
Released on 2021/12/23
Released on 2021/12/17
Released on 2021/11/16
  • NEW: Virtual MIDI Loopback
  • Add button color for banks
  • New MOD Dwarf logo
  • Add opus audio file support
  • NEW: MOD Dwarf support
  • General UI improvements
  • New device screen layout
  • New font
  • Fix sporadic boot issues
  • fix disabling snapshots
  • minor UI fixes
  • small cosmetic fixes
  • NEW: Actuator groups
  • Support for new Duo X unit
  • MIDI Clock slave and output
  • Unlocked parameters
  • User profiles
  • Fixed small all around bugs
  • Renaming unstable -> beta
  • Settings button
  • Minors
  • NEW: Global Tempo
  • NEW: Settings Panel
  • Add zita-njbridge package
  • fix audio inputs DC offset
  • Control Chain support
  • tuner added to 2nd display
  • several optimizations
  • Sort plugins ignoring case
  • Fix missing favicon images
  • add auto-upgrade system
  • Fix save dialog auto-focus
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
