Bluetooth options
Your MOD device has a menu option dedicated to Bluetooth. Screens might look slightly different for different devices. For example, for MOD Duo / Duo X, please click and hold the left knob and scroll down to the "System" menu
Connecting using Bluetooth
Windows
2. Turn on the MOD device
Mac OS
3. Wait for it to boot
Connecting to mobile devices
iOS
Android
3. On the settings of your Android device turn off the internet connection. Normally this is done on the WLAN selector. Also turn off 4G/mobile data too, if you have that.
| Dongle | Dongle chipset | Chipset VID:PID | MOD Device | MOD Release | Test | User | Date | Device + OS |
| Maxuni Bluetooth 5.0 - https://www.amazon.com/dp/B08CMP5LQC | MOD Dwarf | Passed | redcloud | 2022-01-26 | iPad 7 | |||
| Maxuni Bluetooth 5.0 - https://www.amazon.com/dp/B08CMP5LQC | MOD Dwarf | Not passed | redcloud | 2022-01-26 | Android 4, 10 | |||
| Avantree DG40S USB Bluetooth https://www.amazon.fr/dp/B00VWEK4IG | MOD Dwarf | Passed | zwabo | 2022-04-21 | Android 11 Samsung Galaxy A32 | |||
| Kinivo BTD400 - https://www.amazon.co.uk/dp/B007Q45EF4 | BCM20702 | 0A5C:21E8 | MOD Dwarf | 1.12.1 | Passed | sloedowncadet | 2023-01-11 | Windows 11 |
| Kinivo BTD400 - https://www.amazon.co.uk/dp/B007Q45EF4 | BCM20702 | 0A5C:21E8 | MOD Dwarf | 1.12.1 | Passed | sloedowncadet | 2023-01-11 | Android 12 Samsung Galaxy S10e |
| tplink UB4A - https://www.amazon.co.uk/dp/B07YLDVM6B | CSR CSR8510 | 0A12:0001 | MOD Dwarf | 1.12.1 | Passed | sloedowncadet | 2023-01-11 | Windows 11 |
| tplink UB4A - https://www.amazon.co.uk/dp/B07YLDVM6B | CSR CSR8510 | 0A12:0001 | MOD Dwarf | 1.12.1 | Passed | sloedowncadet | 2023-01-11 | Android 12 Samsung Galaxy S10e |
| Olakin BT5.1 - https://www.amazon.co.uk/gp/product/B09ZY2MTXT | Realtek RTL8671b | 0BDA:A725 | MOD Dwarf | 1.12.1 | Unsupported | sloedowncadet | 2023-01-11 | - |
