Bluetooth options
Connecting using Bluetooth
Windows
2. Turn on the MOD device
Mac OS
3. Wait for it to boot
Connecting to mobile devices
iOS
Android
3. On the settings of your Android device turn off the internet connection. Normally this is done on the WLAN selector
User | Device + OS | MOD Device | Test | Dongle |
redcloud | iPad 7 | MOD Dwarf | Passed | Maxuni Bluetooth 5.0 - https://www.amazon.it/gp/product/B08CMP5LQC |
redcloud | Android 4, 10 | MOD Dwarf | Not passed | Maxuni Bluetooth 5.0 - https://www.amazon.it/gp/product/B08CMP5LQC |
zwabo | Android 11 Samsung Galaxy A32 | MOD Dwarf | Passed | Avantree DG40S USB Bluetooth https://www.amazon.fr/dp/B00VWEK4IG/ |
