| 1.11 | 2022/05/05 | Virtual MIDI Loopback; Snapshots rework; Audio processing options; Bank, pedalboard and snapshot management; Controller feedback for plugins | Duo: modduo-v1.11.5.2841.tar Duo X: modduox-v1.11.5.2836.tar |
- 3 Release 1.12
- 4 Release 1.11
- 5 Release 1.10
- 6 Release 1.9
- 7 Release 1.8
- 8 Release 1.7
- 9 Release 1.6
- 10 Release 1.5
- 11 Release 1.4
- 12 Release 1.3
- 13 Release 1.2
- 14 Release 1.1
- 15 Release 1.0
- 16 Release 0.15.0
- 17 Release 0.14.0
- 18 Release 0.13.0
- 19 Release 0.12.2
- 20 Release 0.11.3
- 21 Release 0.10.4
- 22 Release 0.9.0
Release 1.12
v1.12-RC1
Work-in-progress!
- update Duo and Dwarf Linux kernel to 5.17.x
- many system tweaks
Duo X specific:
- NEW: USB-B mode options
Dwarf specific:
- NEW: LED brightness option
v1.11.6
Unreleased
- notify plugins of buffer size change (from 128 to 256, or vice-versa)
v1.11.5
Released on 2022/05/05
- fix support for MediaTek MT7601U bluetooth device (Duo X only, per user request)
v1.11.4
Released on 2022/04/08
Dwarf specific (device side):
v1.11.3
Released on 2022/03/11
- add "/allguis" special page
Dwarf specific:
v1.11.2
Released on 2022/02/11
Duo X specific:
Dwarf specific:
v1.11.1
Released on 2022/01/28
Dwarf specific:
v1.11.0
Released on 2021/12/23
Released on 2021/12/17
Released on 2021/11/16
Duo X specific changes:
- NEW: Virtual MIDI Loopback
- Add button color for banks
- New MOD Dwarf logo
- Add opus audio file support
