Max gen~
Apart from programming LV2-plugins in a "traditional" way, it's also possible to generate LV2-plugins for MOD devices from gen~ objects created in Cycling '74 Max.
Gen basics
Designing your effect in Gen
Getting your Gen-based plugin to a MOD device
At this point you should have met the requirements specified above. If so, follow the steps below to get your plugin on a MOD device.
In order to run Gen-based plugins on a MOD device they must be converted into LV2 plugins and compiled using a custom MOD cloud build system.
Your plugin will now be transferred to the MOD device, within a few minutes the MODwatcher will tell you if the upload succeeded.
Compiling the plugin
First, download https://download.moddevices.com/releases/max-gen/max-gen-deploy_v6.tar.gz and extract it.
Send an "exportcode" message to the gen~ object in your main Max-patcher to get the gen_exported.cpp and gen_exported.h files.
$ cd /path/to/max-gen-deploy/
Editing the plugin
OPTIONAL
$ tar -xzvf Plugin.lv2-dwarf.tar.gz
$ rm Plugin.lv2-dwarf.tar.gz
$ ./mod-deploy.sh
