Max gen~
Revision as of 01:34, 20 April 2022 by FalkTX (talk | contribs) (max-gen-deploy_v6)
Apart from programming LV2-plugins in a "traditional" way, it's also possible to generate LV2-plugins for MOD devices from gen~ objects created in Cycling '74 Max.
Gen basics
Designing your effect in Gen
  • To get your gen~ object working on a MOD device, you'll need to design one using only Gen's internal objects, without referring to objects outside the gen~ object.
    Only the objects inside will make it to the final LV2-plugin.
  • If you want controllable parameters, define the default, minimum and maximum arguments in the "param" object.
  • While designing your gen~ object, remember that all MOD devices are running at 48 kHz sampling rate.
Getting your Gen-based plugin to a MOD device
At this point you should have met the requirements specified above. If so, follow the steps below to get your plugin on a MOD device.
In order to run Gen-based plugins on a MOD device they must be converted into LV2 plugins and compiled using a custom MOD cloud build system.
  • Go to or install the MOD Duo-package in the Package Manager in Max if you haven't, and click on Launch.
  • Make sure your MOD device is connected, then start the MODwatcher from the popped-up screen.
  • If you want your plugin to have a name, copy your gen~ objects contents to a gen~ object with a patcher-name argument.
    WARNING: naming your original gen~ object will initialize it's contents.
  • Finally send a message containing "exportnotifier MODwatcher, exportcode" (without the quotation marks) to the gen~ object.
Your plugin will now be transferred to the MOD device, within a few minutes the MODwatcher will tell you if the upload succeeded.
Compiling the plugin
First, download https://download.moddevices.com/releases/max-gen/max-gen-deploy_v6.tar.gz and extract it.
Send an "exportcode" message to the gen~ object in your main Max-patcher to get the gen_exported.cpp and gen_exported.h files.
$ cd /path/to/max-gen-deploy/
$ ./mod-build.sh
Editing the plugin
To add units, knob behavior or a description, you'll have to edit the .ttl file. If you do so, make sure everything is correct,
OPTIONAL
$ tar -xzvf Plugin.lv2-duo.tar.gz
$ rm Plugin.lv2-duo.tar.gz
Deploying the plugin
$ ./mod-deploy.sh
