Stable Releases
1.11 2022/02/11 Virtual MIDI Loopback; Snapshots rework; Audio processing options; Bank, pedalboard and snapshot management; Controller feedback for plugins Duo: modduo-v1.11.2.2675.tar
Duo X: modduox-v1.11.2.2676.tar
Dwarf: moddwarf-v1.11.2.2677.tar
Duo X: modduox-v1.7.4.855.tar
  1. Turn on your MOD
Release 1.12
v1.12-RC1
Work-in-progress!
  • many system tweaks
  • update Duo and Dwarf Linux kernel to 5.16.11
Duo X specific:
  • NEW: HMI Widgets support (aka controller feedback for plugins)
  • initial support for Duo X production units (with firefly rk3399 SoM)
v1.11.3
Work-in-progress!
  • add "/allguis" special page
Dwarf specific:
v1.11.2
Released on 2022/02/11
Duo X specific:
Dwarf specific:
v1.11.1
Released on 2022/01/28
Dwarf specific:
v1.11.0
Released on 2021/12/23
Released on 2021/12/17
Released on 2021/11/16
Duo X specific changes:
  • NEW: Virtual MIDI Loopback
  • Add button color for banks
  • New MOD Dwarf logo
  • Add opus audio file support
  • NEW: MOD Dwarf support
  • General UI improvements
  • New device screen layout
  • New font
  • Fix sporadic boot issues
  • fix disabling snapshots
  • minor UI fixes
  • small cosmetic fixes
  • NEW: Actuator groups
  • Support for new Duo X unit
  • MIDI Clock slave and output
  • Unlocked parameters
  • User profiles
  • Fixed small all around bugs
  • Renaming unstable -> beta
  • Settings button
  • Minors
  • NEW: Global Tempo
  • NEW: Settings Panel
  • Add zita-njbridge package
  • fix audio inputs DC offset
  • Control Chain support
  • tuner added to 2nd display
  • several optimizations
  • Sort plugins ignoring case
  • Fix missing favicon images
  • add auto-upgrade system
  • Fix save dialog auto-focus
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
