Developers
Technical information
The compiler is GCC 4.9 on Duo and Duo X, GCC 7.5 on Dwarf.
For the Duo X the flags are:
And for the Dwarf:
Plugin Development
mod-plugin-builder
In summary:
$ cd mod-plugin-builder
$ ./bootstrap.sh <platform>
If you are lacking on time or disk space (needed ~15G) you can use "minimal" as argument after the platform which will only build the compiler and the bare minimum libraries.
$ pushd ~/mod-plugin-builder/
$ source local.env <platform>
$ popd
$ make
Quick example plugin
See https://github.com/moddevices/mod-plugin-builder/tree/master/plugins/package/eg-amp-lv2-labs/source
$ cd ~/mod-plugin-builder/
$ source local.env modduo
$ cd ~/mod-plugin-builder/plugins/package/eg-amp-lv2-labs/source/
$ make
Deploying plugins
APIs and Documentation
LV2
For reference/external information see:
JACK
For more information see:
Toolchain
- GCC 4.9
- glibc 2.21
- binutils 2.25
While the MOD Dwarf uses:
- GCC 7.5
- glibc 2.27
- binutils 2.26.1
Note: Within mod-plugin-builder you can use "modduo-static" or "modduox-static" as platform to get GCC7.5 and binutils 2.26.1.
Libraries
- acl
- alsa
- armadillo
- audiofile
- boost
- cairo
- dbus
- expat
- ffmpeg
- flac
- fluidsynth
- fontconfig
- freetype
- gio/giomm
- glib/glibmm
- glibc (v2.21)
- icu
- jack2
- libffi
- libgig
- libjpeg/libturbojpeg
- liblo
- libogg
- libpng
- libsamplerate
- libsigc
- libsndfile
- libvorbis
- libxml2
- lilv
- lvtk (v1 and v2)
- mxml
- ncurses
- ne10
- pcre
- pixman
- python (v3.4)
- readline
- sdl
- serd
- sord
- sratom
- systemd (v219)
- zita-convolver
- zita-resampler
Developer mode
This includes:
- Network statistics
Useful links
USB Device Support
- Any regular joystick
Hardware Specification
MOD Duo
CPU:
- Dual Core ARMv7 1.0GHz
- 4GB Flash Storage, 1GB RAM
AUDIO CODEC:
CONTROLLER:
- 2 knobs with LCD screen
I/O CONNECTIONS:
MOD DuoX
CPU:
- 16GB Flash Storage, 2GB RAM
AUDIO CODEC:
CONTROLLER:
- 2 knobs with LCD screens
- 8 analog potentiometers
I/O CONNECTIONS:
