Troubleshooting
- 4 MOD does not boot, stuck on 'MOD Duo' screen
- 6 MOD Duo X screens freeze
- 7 Failed to connect to MOD Cloud
- 8 Using Firefox and 'noscript' add-on prevents loading of cloud pedalboards
- 9 Dealing with noise issues
- 10 Device loses USB connection when the host computer gets in sleep mode
If you are not able to connect to your MOD device using Mac OS, please make sure that your computer didn't get in sleep mode while you had your MOD device plugged via USB. Learn more on "Device loses USB connection when the host computer gets in sleep mode. Otherwise, please check Troubleshooting Mac OS Network
References on Ground Loops:
If your host computer goes to sleep mode while your MOD device is connected to it, you may lose the USB connection to that machine. As a consequence, you stop being able to access the WebGUI.
The cause for this behavior is the "USB selective suspend feature" of your host device.
- After the host device wakes up from the sleep mode, unplug and replug the USB cable between the MOD device and the device. This will re-establish the USB connection;
- Set up the host device so that it doesn't automatically go to sleep mode. Apple - which devices we received reports of this situation - recommends this solution when looking into their forums;
- Depending on the OS of your host device, you can disable the "USB selective suspend feature" for individual USB ports in system settings. However, if you are using an external USB hub (for example, if there is only USB-C and you need to place an external hub), you can't make use of this feature.
