- 3 Release 1.11
- 4 Release 1.10
- 5 Release 1.9
- 6 Release 1.8
- 7 Release 1.7
- 8 Release 1.6
- 9 Release 1.5
- 10 Release 1.4
- 11 Release 1.3
- 12 Release 1.2
- 13 Release 1.1
- 14 Release 1.0
- 15 Release 0.15.0
- 16 Release 0.14.0
- 17 Release 0.13.0
- 18 Release 0.12.2
- 19 Release 0.11.3
- 20 Release 0.10.4
- 21 Release 0.9.0
Released on 2021/12/17
Released on 2021/11/16
Duo X specific changes:
- NEW: Virtual MIDI Loopback
- Add button color for banks
- New MOD Dwarf logo
- Add opus audio file support
