Revision as of 15:25, 17 December 2021 by FalkTX (talk | contribs) (→‎v1.11-RC3)
Stable Releases
Duo X: modduox-v1.7.4.855.tar
  1. Turn on your MOD
Work in progress!
  • add support for per-unit default parameter values
  • tweak popup text to make things more uniform (dwarf only)
Duo X specific changes:
  • NEW: Virtual MIDI Loopback
  • Add button color for banks
  • New MOD Dwarf logo
  • Add opus audio file support
  • NEW: MOD Dwarf support
  • General UI improvements
  • New device screen layout
  • New font
  • Fix sporadic boot issues
  • fix disabling snapshots
  • minor UI fixes
  • small cosmetic fixes
  • NEW: Actuator groups
  • Support for new Duo X unit
  • MIDI Clock slave and output
  • Unlocked parameters
  • User profiles
  • Fixed small all around bugs
  • Renaming unstable -> beta
  • Settings button
  • Minors
  • NEW: Global Tempo
  • NEW: Settings Panel
  • Add zita-njbridge package
  • fix audio inputs DC offset
  • Control Chain support
  • tuner added to 2nd display
  • several optimizations
  • Sort plugins ignoring case
  • Fix missing favicon images
  • add auto-upgrade system
  • Fix save dialog auto-focus
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
