Bluetooth options
Connecting using Bluetooth
Windows
2. Turn on the MOD device
Mac OS
3. Wait for it to boot
Connecting to mobile devices
iOS
4. Go to Settings -> Bluetooth on your iOS device and wait until the MOD device appears on the list of "Other Devices"
4. Click on it and wait to connect
6.You are now connected. Open your the browser on your mobile device and go to http://192.168.50.1/
Android
2. On the settings of your Android device turn off the internet connection. Normally this is done on the WLAN selector
3. Enable the discovery on the Bluetooth settings of your MOD device. On your Android device switch OFF the WLAN (WiFi) and switch ON the Bluetooth. Your MOD device must now appear on the list
5. Click on the MOD device name in order to pair it with your Android
6. As soon as your MOD device is paired, click on its settings and activate the "Internet access" through it
7. You are now able to edit your pedalboard from your Android device. Open the browser on your mobile device and go to http://192.168.50.1/
