Bluetooth options
Connecting using Bluetooth
Windows
2. Turn on the MOD device
5. Click on the 'Add device' button on the new window that appeared on the computer.
6. Select your MOD device from the list and click 'Next'.
7. Wait for Windows to finish setting it up...
9. The connection should be successful. If not, start again from step 3.
Mac OS
3. Open the settings menu of your MOD device as described above.
4. Open System Preferences, go to Bluetooth and wait for your list to update. After a while you must see your MOD device appearing and available to connect
3. Wait for it to boot
Connecting to mobile devices
Here we will let you know how to connect your MOD device via bluetooth with iOS and Android systems.
iOS
4. Go to Settings -> Bluetooth on your iOS device and wait until the MOD device appears on the list of "Other Devices"
4. Click on it and wait to connect.
6.You are now connected. Open your the browser on your mobile device and go to http://192.168.50.1/
Android
2. Enable the discover on the Bluetooth settings of your MOD device. On your Android device switch OFF the WLAN (WiFi) and switch ON the Bluetooth. Your MOD device must now appear on the list
4. Click on the MOD device name in order to pair it with your Android.
5. As soon as your MOD device is paired, click on its settings and activate the "Internet access" through it
Note: this will stop your access to your normal internet on this device.
6.You are now able to edit your pedalboard from your Android device. Open your the browser on your mobile device and go to http://192.168.50.1/
