- 3 Release 1.11
- 4 Release 1.10
- 5 Release 1.9
- 6 Release 1.8
- 7 Release 1.7
- 8 Release 1.6
- 9 Release 1.5
- 10 Release 1.4
- 11 Release 1.3
- 12 Release 1.2
- 13 Release 1.1
- 14 Release 1.0
- 15 Release 0.15.0
- 16 Release 0.14.0
- 17 Release 0.13.0
- 18 Release 0.12.2
- 19 Release 0.11.3
- 20 Release 0.10.4
- 21 Release 0.9.0
WIP
TODO list them all
Dwarf related bugfixes: - handle closing popups better - fix button actions triggering closed popup - fix momentary footswitch display status being incorrect - correct button led's when naming widget is empty - correct pedalboard list getting out of sync when changing banks - fix crash when deleting active bank - fix click list displaying inactive item
DuoX related bugfixes: - fix decimal missing on negative values - fix display flickering when turning pots
- NEW: Virtual MIDI Loopback
- Add button color for banks
- New MOD Dwarf logo
- Add opus audio file support
