- 3 Release 1.11
- 4 Release 1.10
- 5 Release 1.9
- 6 Release 1.8
- 7 Release 1.7
- 8 Release 1.6
- 9 Release 1.5
- 10 Release 1.4
- 11 Release 1.3
- 12 Release 1.2
- 13 Release 1.1
- 14 Release 1.0
- 15 Release 0.15.0
- 16 Release 0.14.0
- 17 Release 0.13.0
- 18 Release 0.12.2
- 19 Release 0.11.3
- 20 Release 0.10.4
- 21 Release 0.9.0
Work-in-progress, not yet released. a non-clean dump of changes follows
- Add Virtual MIDI Loopback
- Improve responsiveness of webgui dynamic parameters, capped at max 40fps
- Fix softlock when loading PB with missing plugins and broken auth
- Fix enumeration/lists step size
- Fix logic around port and film steps (with proper integer support)
- Fix ordering of files when exposed to plugins
- Other minor system tweaks
Dwarf specific changes potentially coming to the Duo and Duo X at a later point:
- Audio processing options
- Bank, pedalboard and snapshot management (with in-device bank and snapshot creation, pedalboard creation coming in v1.12)
- HMI Widgets
- Optimized kernel build
- Reworked controller dialogs (more robust/stable)
- Add "click-list" option for lists on knobs
- Add button color for banks
- Fix play status not always being displayed correctly
- New MOD Dwarf logo
- Add opus audio file support
