Revision as of 14:59, 27 September 2021 by FalkTX (talk | contribs)
Stable Releases
Duo X: modduox-v1.7.4.855.tar
  1. Turn on your MOD
Work-in-progress, not yet released. a non-clean dump of changes follows
  • Use dB units for input and output gain levels
  • Virtual MIDI Loopback
  • Enable all possible Bluetooth USB drivers (depends on each unit kernel)
  • Update zita-resampler from 1.6.2 to 1.8.0
  • Properly strip all binaries
  • Enable systemd journal (Duo X and Dwarf only)
  • NOTE temperature logs still enabled, likely needs to be turned off
  • cairo png support was missing
  • Fix enumeration/lists step size
  • Fix logic around port and film steps (with proper integer support)
  • Better mod-ui debugging (MOD_LOG=1 base, MOD_LOG=1 full)
  • Use full size screenshots as thumbnail if browser devicePixelRatio >= 2 (high-dpi/retina displays)
  • Better handling of smaller browser sizes
  • Improve responsiveness of webgui dynamic parameters, capped at max 40fps
  • Fix softlock when loading PB with missing plugins and broken auth
  • Control chain actuator groups
  • Custom standalone store.html
  • Optimized kernel build
  • Reworked controller dialogs (more robust/stable)
  • Updated bootloader (not finalized yet, might not go in)
Dwarf specific changes coming to the Duo and Duo X at a later point:
  • Audio processing options
  • Bank, pedalboard and snapshot management (in-device bank and snapshot creation, pedalboard creation coming in v1.12)
  • HMI Widgets
  • New MOD Dwarf logo
  • Add opus audio file support
  • NEW: MOD Dwarf support
  • General UI improvements
  • New device screen layout
  • New font
  • Fix sporadic boot issues
  • fix disabling snapshots
  • minor UI fixes
  • small cosmetic fixes
  • NEW: Actuator groups
  • Support for new Duo X unit
  • MIDI Clock slave and output
  • Unlocked parameters
  • User profiles
  • Fixed small all around bugs
  • Renaming unstable -> beta
  • Settings button
  • Minors
  • NEW: Global Tempo
  • NEW: Settings Panel
  • Add zita-njbridge package
  • fix audio inputs DC offset
  • Control Chain support
  • tuner added to 2nd display
  • several optimizations
  • Sort plugins ignoring case
  • Fix missing favicon images
  • add auto-upgrade system
  • Fix save dialog auto-focus
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
