Developers
Technical information
The MOD Duo runs the Linux kernel version 3.4, with real-time patch. Running in a ARMv7 32bit OS.
The MOD Duo CPU is a dual-core Cortex A7, running at a constant 912 MHz. It is possible to set the speed to 1.0GHz, but with the risk of stability issues.
The MOD Duo X CPU is a quad-core Cortex A53, running at a constant 1.5GHz.
The compiler is GCC 4.9.
And the flags for Duo X are:
Useful links
mod-plugin-builder
In summary:
$ cd mod-plugin-builder
$ ./bootstrap.sh <platform>
$ # Where platform can be modduo or modduoxThis process should take at least 1 hour, probably more depending on your CPU.
$ pushd ~/mod-plugin-builder/
$ source local.env <platform>
$ popd
Quick example plugin
Deploying plugins
APIs and Documentation
For more information see:
JACK
LV2
Toolchain
- GCC 4.9
- glibc 2.21
- binutils 2.25
While the MOD Dwarf uses:
- GCC 7.5
- glibc 2.27
- binutils 2.26.1
We are working to bring the same GCC 7.5 to the Duo and Duo X as optional build target, while keeping the same glibc and binutils.
Libraries
- acl
- alsa
- armadillo
- audiofile
- boost
- cairo
- dbus
- expat
- ffmpeg
- flac
- fluidsynth
- fontconfig
- freetype
- gio/giomm
- glib/glibmm
- glibc (v2.21)
- icu
- jack
- libffi
- libgig
- libjpeg/libturbojpeg
- liblo
- libogg
- libpng
- libsamplerate
- libsigc
- libsndfile
- libvorbis
- libxml2
- lilv
- lvtk (v1 and v2)
- mxml
- ncurses
- ne10
- pcre
- pixman
- python (v3.4)
- readline
- sdl
- serd
- sord
- sratom
- systemd (v219)
- zita-convolver
- zita-resampler
Developer mode
This includes:
- Network statistics
- Xrun counter (aka audio drop-outs)
enable_dev_mode()
disable_dev_mode()
Beta/Unstable plugins
- For releases 1.5.0 and later, there is an option on the special settings page: http://modduo.local/settings (or http://192.168.51.1/settings if you don't have zeroconf working).
- For earlier releases, open the browser development console and enter:
Use with caution.
USB Device Support
- Any regular joystick
Hardware Specification
MOD Duo
CPU:
- Dual Core ARMv7 1.0GHz
- 4GB Flash Storage, 1GB RAM
AUDIO CODEC:
CONTROLLER:
- 2 knobs with LCD screen
I/O CONNECTIONS:
MOD DuoX
CPU:
- A53 quad core 1.4 Ghz + A72 dual core 2 Ghz
- 16GB Flash Storage, 2GB RAM
AUDIO CODEC:
CONTROLLER:
- 2 knobs with LCD screens
- 7 pushbuttons with color LEDs
- 8 analog potentiometers
I/O CONNECTIONS:
- SPDIFF output – 3.5mm-jack – for digital audio output
