Revision as of 12:24, 3 August 2021 by FalkTX (talk | contribs) (→‎v1.10.2)
Stable Releases
1.10 2021/03/30 File handling; Actuators addressing improvements; Redesigned Duo screen layout; More complete LV2 implementation Duo: modduo-v1.10.1.2236.tar
Duo X: modduox-v1.10.1.2235.tar
Dwarf: moddwarf-v1.10.1.2234.tar
Duo X: modduox-v1.7.4.855.tar
  1. Turn on your MOD
Released on 2021/08/xy
  • New MOD Dwarf logo
  • Add opus audio file support
  • NEW: MOD Dwarf support
  • General UI improvements
  • New device screen layout
  • New font
  • Fix sporadic boot issues
  • fix disabling snapshots
  • minor UI fixes
  • small cosmetic fixes
  • NEW: Actuator groups
  • Support for new Duo X unit
  • MIDI Clock slave and output
  • Unlocked parameters
  • User profiles
  • Fixed small all around bugs
  • Renaming unstable -> beta
  • Settings button
  • Minors
  • NEW: Global Tempo
  • NEW: Settings Panel
  • Add zita-njbridge package
  • fix audio inputs DC offset
  • Control Chain support
  • tuner added to 2nd display
  • several optimizations
  • Sort plugins ignoring case
  • Fix missing favicon images
  • add auto-upgrade system
  • Fix save dialog auto-focus
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
