File handling
Getting Started
How to upload a file
Available file types
Audio Files
- aif
- aifc
- aiff
- au
- bwf
- flac
- htk
- iff
- mat4
- mat5
- oga
- ogg
- paf
- pvf
- pvf5
- sd2
- sf
- snd
- svx
- vcc
- w64
- wav
extra through ffmpeg:
- 3g2
- 3gp
- aac
- ac3
- amr
- ape
- mp2
- mp3
- mpc
- wma
Audio Loops
Audio Recordings
Audio Samples
Audio Tracks
Impulse Response Files
- aif
- aifc
- aiff
- flac
- w64
- wav
Instruments
Hydrogen Drumkits
SF2 Instruments
SFZ Instruments
MIDI Files
For MIDI files basically.
- mid
- midi
MIDI Clips
MIDI Songs
Audio Files
MIDI Files
Impulse Responses
A plugin for reverb IR files from the LSP suite. Possible maximum size of IR depends on the device (Duo cannot handle much, Duo X is much better). MOD port in development, available as beta for now.
Instruments
An SF2 loader/synthesizer.
