Dwarf Technical Specs
Technical specs
- length: 105 mm
- width: 202 mm
- height: 54 mm
Processor
- RockChip PX30 CPU:
- CPU family: ARM A35
- Platform bit depth: 64 bit
- Cores Clock: 4 x 1.3GHz
- Memory: 1 GB RAM
- Flash Storage: 8 GB
Audio
- TRS connectors Unbalanced
- Input impedance 1 MΩ
- TRS connectors Balanced
- Volume Control: 0dB to -127dB, adjustable in 0.5dB steps;
- Headphone output:
- 3.5mm TRS connector
USB
- USB Host
- Connector: Type-A
- Standard: USB 2.0
- USB Device
- Connector: Type-B
- Standard: USB 2.0
Device Controller
- 1x 2.9" LCD display
- 3x endless knobs
- 3x push buttons (that allow you to switch between control assignments pages) (backlit with colour LED's)
Peripherals
Software
The MOD Dwarf runs the MOD runs the latest Operating System. Support for the MOD Dwarf was added to the MOD OS on version 1.10.
